1 - 8 of 8 Posts
I have been running Vista for a month now quite sucessfully. I always used a registry cleaner with my XP. I was looking for a registry cleaner for Vista and got blasted on the Vista neagroup for even using a registry cleaner. I think they work and work quite well.<br />
<br />
Does anyone use or believe in registry cleaners?
<tr>
<div>
Originally Posted by <strong>Badgerman</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1397531#post1397531" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">I have been running Vista for a month now quite sucessfully. I always used a registry cleaner with my XP. I was looking for a registry cleaner for Vista and got blasted on the Vista neagroup for even using a registry cleaner. I think they work and work quite well.<br />
<br />
Does anyone use or believe in registry cleaners?</div>
</td>
</tr>
</table>
</div>I've used registry cleaners and a registry optimiser for years. They do work and have a beneficial effect, imo. Not everybody agrees though <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> .<br />
<br />
Highly-Annoyed
<tr>
<div>
Originally Posted by <strong>Highly-Annoyed</strong>
<a href="showthread.php?s=d51c1a11b1f7d586c94ba64097780a71&p=1397539#post1397539" rel="nofollow"><img class="inlineimg" src="http://static.overclock.net//img/forum/go_quote.gif" border="0" alt="View Post" /></a>
</div>
<div style="font-style:italic">I've used registry cleaners and a registry optimiser for years. They do work and have a beneficial effect, imo. Not everybody agrees though <img src="/images/smilies/wink.gif" border="0" alt="" title="Wink" class="inlineimg" /> .<br />
<br />
Highly-Annoyed</div>
</td>
</tr>
</table>
</div>I'm with Highly-Annoyed on this one. I use them and love them. <br />
<br />
(CCleaner and NTRegotp in my case.)
I use CCleaner to clean it up...<br />
<br />
They DO work. Sometimes if you have an entry that it doesn't find something for...it'll bring up error messages or something...<br />
<br />
Plus, it's juts faster.
Im a happy CCleaner user too, works a treat<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" /><br />
<br />
As for a Vista version im not 100% sure, i found this <a href="http://www.registry-cleaner.net/vista-registry-cleaner.htm" target="_blank">LINK</a> but im not to sure on it.
I use CCleaner, it's a great program.
Administrator
Tweaking and removing old or bad registry entries can make alot of difference to computer performance..Apart from Ccleaner a program Called Registry mechanic is also very good : <a href="http://www.pctools.com/registry-mechanic/?ref=google_rm" target="_blank">http://www.pctools.com/registry-mechanic/?ref=google_rm</a>
I use both CCleaner and Registry Mechanic. My preference is for Registry Mechanic although its not free - its the safest r cleaner out there. Some of the others are too aggressive and cause more troubles than they cure.
1 - 8 of 8 Posts
