1 - 6 of 6 Posts
Well, just recently I got a killer deal on a HIS 5970 ($400 with an unactivated warranty) from my friend, hardly used (4 months). I upgraded from a XFX 5770, the CCC driver appear to be okay right now at 10.12, games run okay but, when I first installed the 5970 and reinstalled the CCC driver it tried to set the core and mem speeds to the 5770's! I reset the clocks back to stock but, I'm still thinking about reinstalling Window's.. Is my thinking worth considering? Thanks in advance.. -Mini.
You don't need to re-install Windows. Whenever you un-install CCC it keeps your old profiles just in case.
(appdata\\local\\ati\\ace\\profiles.xml)
Delete this and reboot, go from there
Reactions: Minigunner
1 - 6 of 6 Posts
