Ah, the "Trusting the Tom" thing, coming out in another thread...Originally Posted by Frozenoblivion
http://www.dazmode.com/store/product/raystorm-750-rs240-watercooling-kit-intel-and-amd-computers/
I'd rather get that.
The H220's performance isn't that great (TTL review) and Tom really has a good point.
On topic: Beginning of March? Pre-order on NCIX
His review was as full of crap as my toddler's suits.
Messing with the fans and not using the stockers as described?
comparing it to the H100i, which is a SEALED loop system, when the H220 is an EXPANDABLE system?
There's a DOZEN other points that can be contended, but the best part is remembering that he's sponsored by Corsair.
As for AMAZON: Swiftech does not have a seller's arrangement with them, so no dice there.
FrozenCPU and one or two others, as well as (obviously) Swiftech themselves will have them available starting next week.
See this thread:
http://www.overclock.net/t/1345816/various-swiftech-h220-240mm-aio-water-cooler-expandable/2130#post_19406323
For details, questions and answers from ST reps, and the controversy and response to Tom's (dismally performed) review.
Thanks - T
messing with the fans how ? he had them at 12v that would be the best speed they could go thus the best performanceOriginally Posted by Thrasher1016
Exactly...
AS POSTED BY GABRIEL R. FROM SWIFTECH:
Dear Forum members, in response Mr Tom Logan's review on overclock3d.net, I have the following comments which I would like to share with you here.
I. On the subject of Performance of the H220 relative to Corsair H100i on the 2011 platform at approximately equal fan speed.
Our observations are as follows:
Possible factor #1 - operating fan speed : Swiftech was tested at fixed 12v (1800 rpm) and Corsair H100i was tested in Balanced mode.
According to Corsair, I cite:
"The "Low Noise", "Balanced", and "High Performance" settings are not strict fan RPMs, but performance curves that let the fans spin up based on internal coolant temp. Their settings are as follows:
Low Noise - 900 RPM to 1300 RPM
Balanced - 1300 RPM to 2000 RPM
High Perf - 1600 RPM to 2600 RPM"
Therefore, because of the high heat load generated by this particular processor (150W +++) it is possible/likely that the Corsair fans operated at their maximum of 2000 RPM in such balanced mode (versus the H220 1800 RPM), which certainly could account for a 2C loss for the Swiftech unit against the Corsair.
Possible factor #2 -Thermal compound - Assuming that all units were tested with the same thermal compound
In our own lab testing, and at high temperature loads, we have measured more than 2C difference between our TIM-Mate 2 and Corsair's pre-applied compound. So by testing the units with a better compound than the original pre-applied stuff, this could artificially boost performance of the Corsair by up to 2C, which is not representative of the product performance "as shipped".
For further clarifications, Swiftech's position on the subject matter of doing comparative testing/reviews of AIO units is that they should be tested in two stages, and the relevant data reported to readers as follows:
1. "as received", based on the rationale that the vast majority of these products is sold to first time users who do not generally replace the thermal compound, particularly when it is pre-applied, and
2. with the same thermal compound so as to establish the thermal characteristics of the product using the same baseline, which provides additional information to the more advanced users.
For the record, all comparative test data published by Swiftech is based on item 1 in accordance with the above stated belief.
Conclusions:
Both of the above factors combined yield up to 4C or more in favor of the Corsair. When readjusted downwards as such, the data would be consistent with our own testing at +/- 1C. In effect, we observed in our lab that the Corsair H100i unit performed substantially better than the earlier H100 version on the Socket LGA 2011 platform compared to 1155 and 1366, and came close (by 1.7C) to the performance of our H220 at equal fan speed on this particular platform.
II. On the subject of Expandability and other matters
• We noticed a factual error in Mr Logan's presentation, and would like to correct it; he says erroneously and I cite: "it is technically a DDC". As explained at length in our video presentations the pump is entirely Swiftech developed and Swiftech manufactured. It is not "Technically" a Laing Made DDC.
• We cannot respond in details to Mr Logan's comments on the subject of our kit's expandability, such as adding a VGA in particular, becasue the opinions expressed by Mr Logan are not backed by factual data. We can only state that we DEMONSTRATED the product to be fully expandable to a full panel of media specialists during CES.
III. On the subject of tubing length
We could not but notice Mr Logans' extreme frustration regarding the above subject matter. What we can respond with is this:
o as far as the primary target user is concerned (first time user), we intentionally supply longer tubing than other AIO kits with the H220 because we genuinely believe that it will provide more choices to users in terms of installation of the product in their case, such as frontal installation, or installation at the bottom of the case.
o As far as the DIY enthusiast user is concerned, our decision was based on the rationale that the H220 tubing can be replaced at will by such users.
We want to thank overclock3D.net for granting a Gold Award to the H220 CPU cooler, and hope that the above commentaries will further assist users in deciding which kit is right for them.
Gabriel Rouchon
CEO
As for your specific questions:
He compared this setup to multiple others, not just one.
He utilized the fans and pump running at full speed, then claimed that they were "noisy" compared to other AIO units.
He griped about the tubing, but forgot, somehow, that this was made to be modified.
Also citing a 2011 CPU for temps is a bit silly, when that's a notoriously hot burner.
Seeing as how he's bought and paid for by the competition, I'll be content to wait for Martin to finish his "walking test", thank you very much.
http://martinsliquidlab.org/2013/01/27/swiftech-h220-prefilled-2x120mm-water-cooling-kit/
Definitely NOT going to let the lack of credibility sway me, or anyone that will listen.![]()
Just my 2c, but I did want to repost Gabe's response over at the Swiftech thread, and let ya'll see that!
Thanks - T
So, the Corsair H100i is constantly on sale for around 110$ or less.Originally Posted by Thrasher1016
Conclusions:
Gabriel Rouchon
CEO
Thanks - T
They had the H220 is the RV02, that case is amazing, since the 90 degree rotation makes for airflow that "makes sense" (according to silverstone). But the H100i was in the 650D, which doesn't have as much room nor the airflow as the RV02 does.Originally Posted by Greenback
so he didn't mess with the fans he let the h220 and the h100i perform to their best and the h100i won how is that a crap review?
a link swiftech have on their H220 page for their fair comparison of h220 to h100i
http://www.xcpus.com/reviews/corsair-h100i-vs-the-swiftech-h220
it's done on different systems and cases yet they have this in front of the link Compared to Corsair's H100i: tell me which review is more fair
I'd go with the H100i if someone didn't want to go full watercooling.
I don't recall him mentioning a kit. He said loop.Originally Posted by Greenback
I actually don't agree on toms bit about getting a kit over this my reasons:
1 if you are not sure about AIO or custom this has both choices
2 if you decide to go custom and do gpu the price between this and a kit is the price of another rad so all you need pay for is the block and a couple of 3/8 5/8 fittings and tubing
my mistake been a couple of days since I watched it but I can see the value of having this
yes
I have an H80i in my Phantom 410, but I would rather get the RS240 or the H100i.Originally Posted by Radmanhs
ok, i was looking at several coolers now
I have a phantom 410 case
The:
H100i
H80i
Kraken x40
RayStorm 750 RS240 WaterCooling Kit
H220
I am thinking of getting the h100i or h80i because then seem to have the best price ratio out of these unless if i hear differently
which one would you recommend and what speeds should i be able to hit with that cooler while still staying at reasonable temps
