1 - 1 of 1 Posts
The easiest way to remove rivets is with a screwdriver.
Take the screwdriver and screw a pointed tip screw inside the rivet.
When the screw is inside, move the head of the screw up and down and pull. If the head of the rivet is not removed try again, if the rivet tail stays inside just tap it with a nail. Be carefull don't do any damage to the case.
1 - 1 of 1 Posts
