Removing [email protected] Service
474 Views 4 Replies 4 Participants Last post by  jbrown
I just installed the graphical version of [email protected] so I want to remove the service that was installed by the console version...anyone know how to do this?
1 - 5 of 5 Posts
Good question..It should of been removed when you reved the application then again you dontnistall the text version as its a command promp kind of program so are u sure the service your looking at is not part of your graphical version.
yea since you dont install the console version, I just had to delete the folder to remove it...the service is still there though because it says in the service name the directory where I had the console version installed (different than the graphical one)
You can just go into your Control Panel / Administrative Tools / Services and either remove or disable the console in service mode.
WOW TYVM
Worked Great =)
REP+
1 - 5 of 5 Posts
