1 - 3 of 3 Posts
Ok, so with my last card (9600GT) I was able to just take the shroud off by undoing a few screws. So I'm wanting to take the shroud off of my 260, but it looks like the only way to do it is to pull the entire cooler (don't want to screw with TIM right now). Is this the case or am I just mistaken?
Ore Wa Gundam
If it's a reference Shroud, they're all only taken off via the heatsink as far as I know. (You probably know already, but all screws on the bottom except the 8 screws in the centre of the PCB-which hold the core-trim in place & the 2 on the mounting plate -for those viewing this in light of how-to).
So yeah, need some TIM it seems ;p
Far as I know, only the newer non-ref Gainward/Palit's have shrouds that're easy to get off.
1 - 3 of 3 Posts
