1 - 11 of 11 Posts
I was wondering is it possible to remove the heat spreaders on my Corsair XMS2? If so, can someone tell me how? I'm afraid I'll break it or something if I attempt to pry it off.
If you do remove them it would void the warranty.<br><br>
Why would you want to take them off?
Ya, just pull them off..lol. But, why? Most good heatspreaders actually help...unless you're getting ramsinks....
Discussion Starter #6
Oh sorry, I forgot to mention why. I wanted to replace it with LED heatspreaders. Or...is there another way to add LEDs to it?
Lol don't void your warrenty just to make them look nice, just attach an LED fan next to them or something <img alt="" class="inlineimg" src="/images/smilies/smile.gif" style="border:0px solid;" title="Smile">. Some RAM like the mushkin RAM, has the heatspreaders attached on in a special way and taking them off will damage something.
Discussion Starter #9
no way to add LEDs to it?<br><br>
Can you lead me a little on the fan? Such as....40mm? or bigger? Where will I put it?
<div>Originally Posted by <strong>dannyyboii</strong></div>
<div style="font-style:italic;">Oh sorry, I forgot to mention why. I wanted to replace it with LED heatspreaders.</div>
</td>
</tr></table></div>
Oh my god, I think I'm gonna <img alt="" src="http://i13.photobucket.com/albums/a291/Coppi/vommit.gif" style="border:0px solid;"><br>
Disco is dead sir.<br><br><br>
Aside from voiding your warranty, you also run the risk of pulling the IC from the PCB, since that the IC is a BGA type IC unlike the ICs in DDR which are soldered into the PCB.<br><br>
Well, BGA is soldered as well but, it's a different process. More fragile it is.
Instead of putting Led heat spreaders, take a look at this <a href="http://www.xoxide.com/neon-crab-memory-cooler.html" target="_blank">http://www.xoxide.com/neon-crab-memory-cooler.html</a> It helps cool and has lights.
1 - 11 of 11 Posts
