1 - 7 of 7 Posts
I am repainting my Antec 900 to do a better job. On the plastic front of the Antec 900, I painted it pretty badly and I am hoping to remove the paint.
Does anyone know what is the best way to remove paint from plastic? I know I can use bumper stripper, but I will have to order it online as the auto store near me does not have it.
Use scotchguard. It makes a huge mess, but it gets the paint off pretty effectively.
Its like $5 for a pack of 3 decent sized sheets. Just about every auto store has it.
(It's also fantastic for giving metal a brushed look)
Either that or you'll need access to a sandblaster.
Good luck
-Jason
Discussion Starter #4
Originally Posted by vwgti
Any biodegradable paint stripper should work without harming the plastic.
Do you have any examples? I did check previously with 2 hardware stores (Ace and Home Depot) regarding paint strippers and they were even surprised when I asked them if there is a paint stripper that is safe on plastic.
Also regarding scotchgard, ill try that and see how it goes.
Any citrus based stripper, its low tox and takes a while to eat through paint like 30-60 mins so shouldnt hurt the plastic. As long as your careful and test its reaction on the paint often you should be fine.
I use thison motorcycle plastics prior to refinish and have had zero ill effects, like I said just keep testing how its eating the paint every couple minutes. http://www.homedepot.com/buy/paint/c...gel-54638.html
Only other suggestion is as stated above or some fine wet/dry sandpaper.
Discussion Starter #6
Just wanted to say thanks. I did try the citrus stripper (smelled like orange) and it did melt/soften the plastic a bit, but I was able to remove enough paint to easily sand it down to bare plastic
Sorry to hear you soften up the plastic, hence my warning to test regularly. Glad it helped out and didnt ruin it for you. Took me a couple trys to get using this stripper on plastic down pat. First lesson learned, just leave it in contact for a shorter time next time.
1 - 7 of 7 Posts
