1 - 3 of 3 Posts
Have you popped the heatspreaders off already?
If I had to guess it's all one solid piece with that part painted red. It's budget ram so I can't imagine they went through the effort to tool out two separate pieces to get that look. It would cost more to make and assemble and wouldn't offer any additional cooling.
If you can't separate it from the rest of the heatspreader you can just paint the whole thing. Remove the ram stick first lol.
Actually it is 2 seperate parts, the red part is a thin metalish piece(not sure what material) and it has some play in it I just don’t know how to pop it off
1 - 3 of 3 Posts
