how bad did u score ur mobo? reason i am asking is i had done it b4 and the mobo still works fine....as for the brackets...u will notice a small plug on the underside of ur mobo....this is the pin that locks the black supports to the mobo...what u have to do is use a pointed blunt object that fits onto the pin and push it....meaning u r looking at the mobos clean bald backside and u push it away from u towards the other side which is packed with components..
this way the pin loose out and once u get all of them loose u will be able remove the bracket....
