I hope i am doing this correctly... a brief rundown, we had our system at work suddenly bsod'ing every day, generally numerous times a day. at the time there were a few programs i didnt like on the system so i reloaded windows fresh. we made it a couple months or so and it just started doing it again. through reading some suggestions in other threads by tompsson i discovered blue screen viewer, which i have installed and run and has come up with the errors pointing to ntoskrnl.exe. most go towards ntoskrnl.exe+f20d4. i am currently running driver verifier as well, though i am not sure how to hone in on the problem more than i have at this point. I am beginning to think it is a problem with the memory but wanted to run through here first.
If i did things properly, i have attached the zip file as requested and am also going to copy and paste the questions with answers requested.
The only other piece to this puzzle is i only have access to this computer weekdays between 8 and 2 eastern time. hopefully things will work out well in those parameters.
I appreciate your help and look forward to your response
· OS - Vista/ Windows 7 ? - windows 7 pro
· x86 (32-bit) or x64 ? - 64
· What was original installed OS on system? - windows 7 pro
· Is the OS an OEM version (came pre-installed on system) or full retail version (YOU purchased it from retailer)? - custom built computer, came installed but we do have the disc
· Age of system (hardware) - 1.5 yrs?
· Age of OS installation - have you re-installed the OS? - 2 months, give or take a couple weeks
· CPU - intel core i7-2600 cup @ 3.40 ghz
· Video Card - idk
· MotherBoard - intel dz68db
· Power Supply - brand & wattage
· System Manufacturer - custom by intrex
· Exact model number (if laptop, check label on bottom) - custom
bsodinfo.zip 2392k .zip file
· Video Card - idk
