Howto Modify Grub and Menu List
If you are adding partitions and installing other Linux distros, you will have had problems with either GRUB or the menu.lst.
This guide shows you how to add distros to the menu.lst so that they are bootable from GRUB at startup.
This is an example of how to use the GRUB edit function.
Highlight the menu entry you want to edit, then press 'e', then
highlight the line you want to edit and press 'e'. Add what
you want to the line 'hdd=scsi' etc. and press enter, then
'b' to boot.
Examples of the difference between Linux and GRUB device names.
1st Physical Hard Disc
Linux IDE: GRUB IDE: Linux SCSI: GRUB SCSI:
/dev/hda1 ----(hd0,0)----- /dev/sda1-------(hd0,0)
/dev/hda2 ----(hd0,1)----- /dev/sda2-------(hd0,1)
/dev/hda3 ----(hd0,2)----- /dev/sda1-------(hd0,2)
/dev/hda4 ----(hd0,3)------/dev/sda2-------(hd0,3)
2nd Physical Hard Disc
/dev/hdb1---- (hd1,0)----- /dev/sdb1------ (hd1,0)
/dev/hdb2---- (hd1,1)----- /dev/sdb2------ (hd1,1)
/dev/hdb3---- (hd1,2)----- /dev/sdb1------ (hd1,2)
/dev/hdb4---- (hd1,3)----- /dev/sdb2-------(hd1,3)
These are some examples of how to use GRUB from the command prompt.
Press the 'c' key for the command prompt.
If you want to boot a Linux system on a partition, using it's kernel
/boot/vmlinuz etc., do this.
grub> root (hd0,1)
grub> kernel /boot/vmlinuz root=/dev/hda2 ro
grub> boot
(you can also copy and paste the above (minus the "grub>" to the menu.lst)
You could do this to find what partition the kernel is on.
For example, show me what partitions have a /boot/vmlinuz.
grub> find /boot/vmlinuz
(hd0,1)
(hd0,2)
If you want to boot a Dos/Win partition, do this.
For example, boot partition on /dev/hda1.
grub> rootnoverify (hd0,0)
grub> makeactive
grub> chainloader +1
grub> boot
If you want to boot a FreeBSD partition using /boot/loader.
For example, boot freebsd partition on /dev/hda4.
grub> root (hd0,3,a)
grub> kernel /boot/loader
grub> boot
If that doesn't work, try this instead.
grub> rootnoverify (hd0,3,a)
grub> boot
Press the [Esc] key to return to the GRUB menu.
I regularly test and install new distros and knowing how GRUB works makes life a whole lot easier.
Whe you install Linux, the Grub install at the end should detect all other operating systems on your PC, but sometimes it doesn't, no problem just add it manually.
If you only want to add an already installed distro so that it boots at startup, (maybe you already have Linux installed and now you are installing a second Linux).
Do this in the terminal :-
sudo nano /boot/grub/menu.lst
This will show you a list of all the OS's that can be booted from GRUB.
You now only have to copy the same format, below, after the last OS.
For example, on your harddrive, you have just installed another linux distro on partition 3. You would add this to the menu.lst
title Debian Sid
root (hd0,2)
kernel /boot/vmlinuz-2.6.20-4-486 root=/dev/hdc3 ro
initrd /boot/initrd.img-2.6.20-4-486
savedefault
Remember that you NEED to know the kernel and initrd.image numbers, above is 2.6.20-4-486, otherwise it won't boot. Some linux distros only put "vmlinuz" and "initrd.img".
To find this out, you need to take a peek in the boot folder of the new partition. Like this:-
cd /dev/hdc3/boot
Then to see it's contents, type:-
ls
You can now copy those numbers onto the menu.lst.
To save the file press Ctrl + X then typ "Y" for yes and hit "Enter".
You should now see the other operating system on the list when you reboot the computer.
