1 - 3 of 3 Posts
AMD Overclocker
Hey guys, I was wondering, has anyone tried replacing the stock tim on the gtx 560 reference cards and has it helped at all? I was thinking about trying it, but I don't want to go through all that work for it to either be the same or worse.
It's not going to make a whole lot of differences and I wouldn't bother unless you think your current temps are too high. Generally manufacturers use top quality thermal paste applied very liberally, if you replace it with AS5 or something of the like with good application you won't see a great deal of increase in performance.
1 - 3 of 3 Posts
