1 - 6 of 6 Posts
The front 230mm fan on my HAF-X died. Any suggestions on a replacement? I have read that some people have chosen to go with 4x120mm fans instead.
Gamer
large diameter fans are notoriously terrible. I would go with the 4x120mm if that will fit in the same location
^^This.
Plus, if you buy halfway decent 120mm fans, they will also have a much longer lifespan. 6 years on Noctuas. You can transfer them over to your next case/rig that you build as 120mm are usually standard on most cases.
PC Gaming 1337 Enforcer
Shooting down fallacies
+3
1 - 6 of 6 Posts
