1 - 10 of 10 Posts
i have a gts 250 with cheap iron core chokes. i want to replace them with ferrite chokes. has any one tried that before and is there different ratings of chokes?
more stable voltages by using higher quality chokes
Are chokes incredibly cheap to purchase or something? It seems weird to go into voltage-related modding on a mid-end card...
Thank you for the mini-class
Sorry for kind of reverse-railing your thread, anyone else reading this, please do not let me distract from the OP's question...
i am puting this on a low end card to see if it will work with my gtx 260
Um ... I don't think that chokes play any role in voltage stability. They just clean electro-magnetic interference off the line I believe.
Thus I definitely wouldn't bother unless I had some reason to believe interference was a problem on my card.
and btw no manufacturer uses iron chokes on their card..
iron just kills the purpose of having chokes for that application...
and yeah for beautification if you ask me... I would use some kind of plastic cap or something to hide the choke..instead of replacing it..
A GTS 250 should work just fine as a PhysX card for a GTX 260 main card.
If you were thinking of running them in SLI, then no it will not work. At all. Ever.
I think he means that if replacing the chokes works on his GTS 250, then he will do the same mod to his GTX 260.
1 - 10 of 10 Posts
