1 - 7 of 7 Posts
What's up all.....I'm going to order some replacement cooling for my X1300XT 512Mb model, and I was wondering what are the best heatsinks and fan(s). I don't care about how loud it is (LOL I don't understand why this is usually the biggest concern!). I read on another thread that the ARCTIC COOLING<br>
ARCTIC COOLING Accelero X2 Fluid Dynamic Bearing VGA Cooling Fan with Heatsink is better than the VF900, which is a relief becuase it's cheaper! Also, I saw the Zalman heatsinks at Newegg for $9, so are these good, or which are the best? Thanks for the input, I'm gonna order today or tomorrow, so hook it up with some suggestions please!<br>
Peace out
The X2 and VF900 are about the same (the VF900 might just take it by a degree or two tho).<br />
<br />
Id suggest the X2 if you like or the VF700 should do fine as your card does'nt make much heat.<br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835118117" target="_blank">VF700</a><br />
<br />
<a href="http://www.newegg.com/Product/Product.asp?Item=N82E16835186002" target="_blank">X2</a>
ok that's cool...it says on new egg that the x2 is made for the ATI x1900 series, so will it fit my card?
Err no sorry, never really looked <img src="/images/smilies/tongue.gif" border="0" alt="" title="Stick Out Tongue" class="inlineimg" /><br />
<br />
ATI X1800 series<br />
ATI X1900 series<br />
ATI X1950 series<br />
<br />
VF700 looks good<img src="/images/smilies/smile.gif" border="0" alt="" title="Smile" class="inlineimg" />
Discussion Starter #5
how about that Fatality? Anyone used this fan? It has a higher RPM than the VF900 and VF700, and it's the same price as the VF900. It says that it will fit my card, too.
I'd just get the VF-900. The fatal1ty cooler just looks like a better looking VF-700 since its got the half "flower" copper fins going on for it. VF-900 cools my X1800XT down to around 65-70C for load and I have it OCed to like 730ish/1600
Discussion Starter #7
ok, thanks for the advice. I'm going to get that one, as someone else suggested the vf900 also.
1 - 7 of 7 Posts
