Well if your looking super quiet and willing to pay that much for case fans I would suggest the Gentle Typhoon AP-14s which are a step down from the max RPM ones which are a little louder...the AP-14s would be pretty much inaudible in a case.
However, I think the loudness in your case during folding would be from your GPU fan and not your case fans. I could be wrong but you might want to utilize Rivatuner to set your fan speed lower and see if that is the cause of your noise. If it is then find a good speed for your GPU fan where it will still keep cool at.
Originally Posted by zachh ![]() the reason i dont fold 24/7 or even really leave my computer on over night is purely because its so loud.. at the moment i have the 2 standard 120mm LED fans on the front and a 80mm LED akasa on the side.. i need something quiet that wont decrease my air flow.. the 120mm's are the priority for the time ive been looking at the Noctua NF-P12 Vortex-Control 120mm Quiet Case Fan but im just stuck tbh rep+ for suggestions |
