you could change the fan pretty easily but opening the psu would void your warranty.
and yes you could just not use the rpm wire
cutting the led wires would cause no problem, but may still void the warranty
edit: led fans are all different though, some the wire is wrapped around the fan housing, others there are multiple wires going out from the motor to each led
