1 - 20 of 39 Posts
Has anyone else had the material in there scrotums to try this program I have. Lol.
What kind of results have you guys gotten?
I cant find much on the internet about anyone's clocks or results with the GTX280.
we should start a voltage tuner Club.
EDIT: I would like to see a screen shot of your EVGA Voltage Turner and GPU-Z if possible.
Just tweaked my 9800gx2 and its awesome! My clocks are crazy high now!
not really pushed my GTX295 yet as its on air still bt I got about a 70mhz(700mhz core on stock volts) increase on the core using it.
Well it turns out ati tool doesn't like me. I normally use rthdribl to stress test but as it doesn't show a timer i thought I would use ATi tool as it adds legitimacy to how long its been running. Ati tool had different ideas. it decided to make my pc restart even at stock settings
yikes, 15mins strong low temps high clocks. some reason my gpu-z says my gtx280 is a 55nm i think that may be the reason for my low temps but that is a totally different thread.
Edit: Im at 20 minutes now! thinking of tweaking some more!
Originally Posted by FaceCannon View Post
wow nice!
Yeah I think I've hit a bottleneck with my processor though because I have to run it at stock clocks until my new mobo comes. I can't get my Vantage score above P14500 no matter how high I clock my card.
I can't get much more of an overclock because my GTX 260 is running at 71*C. I need it to be under 60*C to achieve a higher overclock. Nonetheless, EVGA Voltage Tuner is awesome!
I tried another program called Voltage Factory, and I noticed jumps to 1.9v every like 10 minutes. At that rate, my GTX 260 will be dead in a week! EVGA isn't giving me any of these problems!
I actually get lower marks in 3d mark vantage when I raise my voltage with EVGA Voltage Tuner. It just seams to mark the card hotter!
I get some decent overclocking thou with 'evga precision' on my gtx 260(192sp) .
std clocks
576 core clock
1242 shader clock
999 memory clock
o/c clocks- runs smooth with no artifacts
fan speed 100 - 60* temp on load
760 core
1560 shader
1215 memory
volt 1150
but are these clocks stable for gameplay after using voltage reg to get higher than you used to be able to get?
I only overclock my video card for benchmarking. Because It runs most games I play full detail and top rez on std clocks.
1 - 20 of 39 Posts
