1 - 4 of 4 Posts
While trying to overclock, my BIOS managed to get all messed up. After I pulled the battery off the motherboard, waited a few minutes and put the battery back in I re-editted the settings so that it was a RAID 0 and that the two drives were paired. When I try and boot Windows 7, I get a 0x7B error and apparently this is a driver issue. Is there anyway to resolve this? I didn't change any of the hardware in the system, I only reset the motherboard settings. I can't get into the system at all, and the recovery console barely does anything after loading the drivers off the motherboard's disc to see the drive.
try setting to ahci or ide just so it boots then reinstall raid drivers
Will it boot if it was previously set to a RAID 0? The data is striped so I would think it was just blue screen almost automatically. How would I be able to install any drivers if I can't get in the system. Ubuntu 10.10 Live CD sees the drive as a single drive just fine.
From what I know if you have windows on the drive if you originally installed with raid then you can switch to ahci or ide to boot to a drive and they should show up seperately. If you are just using linux boot a live cd and install the linux raid drivers from the live cd to the disks. Your third option would be to connect the drives to a different computer and access the data. Copy it to a backup drive then reinstall but im sure you dont want to reinstall your os
1 - 4 of 4 Posts
