1 - 5 of 5 Posts
Is there anyway to change the resolution of the windows start page. As in the page with the bar that goes across the screen before it boots up. It looks so nice when you first load up sp2 and its in atleast 600x800 resoltion. Maybe via a registry hack?
No, I have been looking into this and from what ive found it needs to be at that low resolution and only in 16 colors. I think with extensive hacks you could get more colors, but to get higher than 640x520 (or whatever) the graphics drivers need to load, and that dosent happen at that stage. (or so Ive read)
You can change what that screen displays though
My roomate has a skin based off of the movie ScarFace, got any links?
You can use stylexp to reskin that image. Just do a search for it, I can't remember the exact site off-hand where it's located.
http://www.tgtsoft.com/
Found it for you.
1 - 5 of 5 Posts
