1 - 20 of 27 Posts
If you have a monitor that is X inches in size and you play certain games at X resolution, if you increase your resolution with the proper ratio for your monitor, are you in fact making objects (such as people you want to shoot in your game) smaller and slightly more difficult to shoot?
You should make the people smaller, but they would probably look really pixely (like if you took AA off).
Don't quote me on that one though.
only fov changes character size, i think...
low fov = more zoomed in = bigger target
high fov = zoomed out/wide angle = smaller target
also, if you run 4:3 rez on a widescreen monitor, the targets will be stretched out and fatter
Originally Posted by Conley
So you're asking what happens if (for example) you have a 20" monitor at 720x480, and you bump it up to 1680 x 1050?
yes.
in my case i have a ''22 and have a preference for 1024x768
Originally Posted by Field View Post
yes.
wth? Seriously? Does your game not look like ass?
Have you tried playing at the "native" resolution on your monitor at all?
Yeah, most 22" monitors have a resolution of 1680x1050. Why is it so low?
22" monitor with res of 1680x1050 = More pixel pitch, less res in X space, bigger objects.
22" monitor with res of 1920x1080 = Less pixel pitch, more res in X space, smaller objects.
That's why I want my 1080P monitor to be not smaller than 27" and that's why I didn't buy a 20" monitor when 1680x1050 monitors first hit the market.
More pixels = more view = more better.
You want the highest pixel density possible. Unless you need glasses but don't wear them, higher res is better.
Nvidia Enthusiast
since you have an ati card you can enable image scaling set it to centered and there you go
Umm, i dont think the size difference is going to be that big of a deal that it will completely hinder your ability to be good at whatever game your playing...
Play at your native resolution. Its the right thing to do.
Discussion Starter · #17 ·
winning and beating other players is all in the details. everything adds up. the goal is not to be ''medium skilled.'' You understand this.
No. If the aspect ratio is the same, the game will render everything the same size (think about it, with that logic, at 640*480, you'd only be able to see the gun). No, on non gaming things, then yes, you'd be right
Originally Posted by SSJ5Broli
some pros game with low res because supposedly it promotes better aim and less chance to miss, I tried it and found it difficult when your enemy is a conflagration of 3 pixels.
This
Honestly, set your settings as high as you can while making sure your framerate is good enough to not hinder you. Things like resolution, etc
I am pretty sure this is wrong. That only works for objects that are measured in pixels, like desktop icons. In-game objects are not measured in pixels, and will therefore be roughly the same size, but much more distorted (if you're keeping the screen size constant while changing resolution).
If you want bigger in game objects, you should increase screen size while keeping the resolution constant, thus increasing the area that would be used to draw, say, a head.
1 - 20 of 27 Posts
