RESOLVED:
Oh my god.. bios must have f'ed up or something, i checked again and the voltage going thru that core was 1.65V (WOW) set it back down to 1.16
I finally managed to get my pc up and running *yay*
But now a new issue *boo*
I was preparing to overclock this Q9550 so I looked @ temps, etc.
Temps were nice and cool @ idle: 28C all around
I did notice my core speed was 2.66ghz (which is weird because I didnt edit the clocks) It should be 8.5*333= 2.83Ghz When i boot into bios to see what was up; the multiplier only went up to 8, not 8.5 (huh?)
and at this point i went to check out the temps within bios and they showed 90C!!!!!! (idle) ***?
Edit: Okay, found out unlinking the ram would pop the multiplier up to 8.5
Originally Posted by xHassassin
Fan speed was normal?
Hmm.. This is weird. Did it ever drop after reaching 90 or did it stay there?
It kind of jumped between 88-90C and yes i put my hands in front of the fans and they were definitely moving air. My fan is a 90CFM it moves a LOT of air.
Only thing that comes to mind is that I didn't correctly apply the TIM (AS5)
I'm thinking it's a messed up sensor. My e6600 reads 50-60 degrees celsius idle in CUPID HW monitor and real temp when it's truly in the low 30's according to the bios.
wow.. good thing you caught that.. everything's normal now right?
Yep! temps back to ~28C, fewf good thing i only had it on for a total of about 2 minutes. I can't be sure if that was my mistake or bios glitching out. I'm going to take the blame for this one though. *Embarrassing*
Overclock.net
