1 - 20 of 20 Posts
I'm building my dad a computer for Christmas, and I found an old Gateway Essentials desktop in my closet (?, I know). I took a picture to get an idea for a mod and this was born! What would you guys think? I have some black vinyl dye, and I'm giving myself a budget of about $45 on the case.
Chackie Jan
Originally Posted by Liability
To hell with that!
Just put the $45 towards a real case... That thing isn't worth putting any amount of money into.
I agree that buying a new case would be a better investment but if you want to mod, do this gateway
I'd love to see how the vinyl dye turns out. Been thinking about vinyl dying(?) my HAF's front bezel white, so I really want to see some vinyl dye on something.
Discussion Starter #5
Well, I may as well dye it, huh? Even if I do buy one, there's no point in the case and dye going to waste.
Awesome, I can't wait to see what it looks like! You totally need to do this. Screw buying a new case, because for Christmas it is the thought that counts! It will show your dad that you put work and effort into making him a present. Subbed!
Discussion Starter #8
I have a dremel, but I've never cut anything intricate like letters. How would you guys go about this?
Chackie Jan
Originally Posted by GeekFreak View Post
Alright, I'll start cleaning off the case tonight, maybe start painting tomorrow.
Cut before you paint/dye it. Well.....I guess it's not a huge deal if you don't but it'll look better if you do.
Discussion Starter #12
I was thinking that, but I need to practice cutting the letters first. I don't want to mess up the case. Good thing I have some extras!
Chackie Jan
Maybe instead of cutting letters out you should just print out the letters on paper, cut those out with an exacto knife and use it as a stencil for spraypainting.
Discussion Starter #14
I kind of want the letters so that when the PC is off, they wont show, and when it's on they light up. But if cutting them is too difficult, then I go with the stencil.
Great idea. The thought and effort would be a cool gift. Good luck.
That's what I did with my skull. I printed a pic of the skull on adhesive paper, traced the design with an exacto knife, which etched the design onto my case, then I use a dremel to cut out the design.
Finally I used the exacto knife, razor blade & sand paper to smoothen & clean up my design.
Discussion Starter #17
Something just hit me... It's only been around 15°F to 35°F the past couple weeks. I don't think any paint would work in that kind of weather. Any ideas? By the way, that skull is incredible looking!
Subbed because the idea is very nice, and the idea in general looks awesome. No you might not want to do some painting in that weather, but I suppose it could be done, though probably isn't recommended. I painted my HAF 932 in the summer.
To that picture above me with that skull, that came out fantastic! Very nice work.
1 - 20 of 20 Posts
