1 - 3 of 3 Posts
Hi everyone,<br><br>
I just finished my first build and I am happy to say that all went well. Soon I will try my hand at overclocking.<br><br>
My question is about using parts from my old Sony PCV-RX450. Does Sony use standard voltages on their power supplies? I will be building my second computer with an Abit NF7-S V2 (in the mail) and a duron processor I have on hand. I thought I read that some companies use propriatary voltages and thought I should check.<br><br>
thanks in advance,<br><br>
druid
Compare the wire colors to the standard used in the link for the 20 pin which you probably have. <br />
<a href="http://pinouts.ru/Power/atxpower_pinout.shtml" target="_blank">http://pinouts.ru/Power/atxpower_pinout.shtml</a>.<br />
If you need the 24 pin, check pg 34-5<br />
<a href="http://www.formfactors.org/developer/specs/ATX12V%20PSDG2.01.pdf" target="_blank">http://www.formfactors.org/developer...20PSDG2.01.pdf</a>
Thanks for the info Duke. That was exactly what I needed. Now I just need to find a good value power supply. This one will not do the job <img src="/images/smilies/mad.gif" border="0" alt="" title="Mad" class="inlineimg" /> <br />
<br />
Thanks again<br />
<br />
druid
1 - 3 of 3 Posts
