1 - 4 of 4 Posts
Administrator
Anyone know any good pointers about this cooler?
Anyone used this cooler?
I think, if it looks good, I will be buying it for my 7800GTX with some good RAM heatsinks (anyone know some good ones?)
Usually it's me who asks questions, but this time I'm asking for opinions
Review:
http://www.bjorn3d.com/read.php?cID=988
That thing is pretty darn big.
Did you see the new ThermalRight?
http://www.overclock.net/ati-cooling...ght+GPU+cooler
That thing looks sweet...and I believe it can be mounted in two ways, depending whether you have space above or below your GPU. (not sure if it's available in the UK)
Yeap: http://www.thecoolingshop.com/produc...oducts_id/2426
Quite a bit more expensive than the one you found though...
These Zalman heatsinks don't look too bad:
http://www.scan.co.uk/Products/Produ...oductID=175079
Two different heights, so easy when you have spots where you don't have a lot of clearance (and I do believe that to be the case with the cooler you're looking at)
Administrator
Discussion Starter #4
Thermalright HR-03.....I think I like the look of that.
Now I think I will need to mount a nice 92mm fan to that. Low RPM fan it recommends...not going to happen (55CFM @ 2000rpm minimum)
Saw the review site, and those were the RAM heatsinks I was looking at. Would prefer Copper ones however, if anyone could find some. Need a Thermal Resistance of at least 0.20C/W if possible
1 - 4 of 4 Posts
