1 - 1 of 1 Posts
in da freezing hell
Hi all,
I'm looking to update my build, when GPU will get back to normal, from the total craze of today.
My rig is in signature.
The upgrade will be:
- GTX 1080 ti
- a custom loop from EKWB (CPU and GPU)
- a new case as there is no way you can have a loop in the V1. It'll probably be its brother, the V21
On top of this, I'd like to put some fancy RGB leds just to show off :)
I'm not clear on something generally with RGB stuff:
- I understand some vendors have monitoring SW that change the leds depending on load/FPS etc ... Are those softwares impacting the gaming ? Is it desirable ? Or better to have a remote ?
- power to the led: what are the best options ? SATA port (I have plenty free) ? Other ?
- can all solutions cycle colors ? Are there many colors possible ?
Sorry, maybe those are noobish questions, but I can't find answers online.
1 - 1 of 1 Posts
