Status
Not open for further replies.
1 - 7 of 7 Posts
The Rig Showcase is great, but for the benchmarks I think there needs to be some subdivisions. Specifically for Sandra because the CPU and memory scores report out several variables and I think the Memory/Cache benchmarks should be addes as well. Well anyway, this is sort of what I was thinking:
Sandra 2004(5) CPU Score:
Arithmetic Score
ALU:
FPU:
iSSE2:
Performance Rating:
Multi-Media Score
Integer x8 iSSE2:
Floating-Point x4 iSSE2:
Sandra 2004(5) Memory and Cache Score:
Memory Bandwidth Score
ALU:
FPU:
Cache and Memory Score
Combined Index:
Speed Factor:
Originally Posted by YiffyGriffy
Bump?
As long as were on the subject. Ifound that if I want to look at someones rig showcase, its hard to find.
It would be nice when you click on someones name and their profile comes up. that there would be a link to their showcase. Its just a little bit of a pain to go through every name till you find the one you want to look at.
Then again I may be blind.
Keyword - Admin
Linux Guru
Keyword - Admin
You can try my alternative means which is to enter the profile, look at a post, then click the Showcase icon on the post. But your recommendation would be better.
yea, the rig showcase is alittle obscure. Would be nice if it was easier to find.
I will look into adding the additional fields asap
Keyword - Admin
- If someone has submitted a rig showcase, a little "
" will appear in their postbit. Click on that and you will go to their showcase
Damn I am blind.
1 - 7 of 7 Posts
Status
