1 - 4 of 4 Posts
IT EXPERT
Hello all ,
I finally get my hands on a I7 4790K cpu with MSI z97a Gaming 7 Motherboard.
I have just overclocked my cpu to 4.7ghz
but my ring frequency is stock which is 4ghz for 4790k.
The system just passed 24hours stability aida test so i know its stable
but i am curious about Ring/Cache Frequency
What it does ( since i was amd user i have no idea)?
Currently it is 4ghz with vring 1.150v
Do i need more or less?
Any Real World Benefits of having high or lower than core frequency?
sorry if its been asked before but i am pumped up and very exited about my new toy
Thanks all
You can overclock uncore frequency if you want. I think this is the clock speed for the North Bridge. Doesn't have an impact on performance really.
Source: http://www.overclock.net/t/1411077/haswell-overclocking-guide-with-statistics#
I got mine at 4.2 GHz Uncore with 1.2V ring voltage. Yours will probably work fine with just 1.150v. I keep mine 400 MHz or more lower than the core clock.
There isn't much of a difference in performance when overclocking the cache on a 4790K, but you can absolutely try if you want to.
IT EXPERT
Discussion Starter #4
Thx
i did more digging around and found some discussion about it shoud be in range of 300-400mhz lower of core clock
So I did some Tweaking in my bios 4.4ghz gave out instant error with 1.150v and
find out 4.3ghz is stable as rock with 1.150v so i went with it so far passed 1 hr stability of aida64
after 1 night of gaming I will do 24 hr aida to make sure its close to perfect stable.
But i can say there is no difference in cinebench and 3dmark firestrike between 4ghz vs 4.3ghz.
1 - 4 of 4 Posts
