1 - 13 of 13 Posts
PC Building Raccoon
I check my case today and low and behold: The fan isn't moving
. It's about two years old now but I wonder if it's fixable. I could have sworn that in the last few months it was running slower then normal. Also it does not spin freely, i'm thinking it might need a lil lube on the pin?
My best guess is the motor is kaput, and Arctic's cooling site is half broken. Any help here? I know a lot of you have this product. Also, CPU temps are 48C-54C right now without it on, pretty damn good cooler, but I'm scared to game now.
EDIT: I got it spinning again, figured I could. But it's acting strange from boot up (after POST) it only loses speed and fluctuates in speed while running, what is going on?
The last fan i tried to 'revive' lasted for 2 more years but then suddenly shorted out and somehow killed my 5870 so I'm now of the opinion just to replace it with a new one.
This. I wouldn't mess with it. See if you can find AC's warranty information. I think the Freezer 7 Pro comes with one.
PC Building Raccoon
Discussion Starter #4
Well I got it on Newegg, but I don't have anything else. Also like I said the support button on their site doesn't even work, neither does the link to a replacement fan.
I'm not replacing the unit. I'm sure it will be fine now, I just wondered if there was a reason for it fluctuating.
Also, A cpu fan could somehow short out the PCI-E slot/card?
I wouldn't want to be the one to test it.
EDIT: http://www.arctic-cooling.com/catalo...=RMA_PROCEDURE
What were you saying about half broken? Seems pretty good to me.
Music Producer
Maybe the fan is covered in dust and it's preventing it from spinning? lol. Just purchase a 92mm fan off newegg and you're set.
PC Building Raccoon
Discussion Starter #7
MY BAD doesn't load in Chrome, sue me.
According to that I guess I would send it back to Newegg, they would probably want the whole unit though.
I clean my case out a lot, of course it's not covered in dust. I doubt they sell cpu cooling fans with a mounting bracket that fits this model, but I could be wrong.
Man with Fans
You say it starts up just fine when it was like new, and then it struggles?
Is there a possibility that inadequate power is being supplied to it?
PC Building Raccoon
Discussion Starter #9
I considered this. But know of no way to change any settings like that. I have a multimeter though, I would check if I knew how to use the thing.
Is the cpu fan power port thermally controlled at all? I wish I had a fan controller in cases like this.
I was going to ask the same thing. Maybe it's PWM acting up or something.
Also, sorry, I didn't mean for that to be taken as hostile. I also didn't know you were using Chrome.
PC Building Raccoon
Discussion Starter #11
Seems to be doing ok now...I think it had something to do with the lubrication really. Does anyone know what kind of bearing the fan uses? I have WD-40 and grease, I just need to know what to put on the fan pin.
WD-40 is a penetrating lubricant and its so light, it won't last long as a lubricant. If by grease, you mean thermal grease, then ok. If you mean grease as a lubricant, then NO. Its too thick and will hinder your fans performance. Go buy some of that 3 in 1 household/electrical oils for $3.99.
Either that or get a 120mm fan and zip-tie to your heatsink.
EDIT: I didn't mean thermal grease as a lubricant. I thought you were implying to reapply.
Reactions: Rushnerd
1 - 13 of 13 Posts
