1 - 10 of 10 Posts
Hello everybody ,
As the caption pretty much says everything . My cm storm sirus is dead . This loss is very tragic to me as currently I don't have any pair of headphones/ headsets . It was last night when my cm storm Sirus's long cable just came under one of the legs of the chair (my poor cable management) and I must be so immersed in gaming that I didn't noticed it . After a very long tiring session of gaming when I decided to take a break and go grab some bear from fridge but unfortunately as soon as I woke up from the chair ..
The cable just broke . The wire just came off (all of it) from headsets completely . It's all over with the sirus . RIP($~160).
For now I am very well just done with these gaming headsets and I regret buying them .They are just complete piece of **** . As for my personnel experience with the sirus for an approximate of two years , they were totally not worth it . The cm storm sirus was very heavy indeed and it also lacked bass , the crisp ,even upon using it with my sound card .
The Colour of the plastic casing started to fade from everywhere ,the leather of the ear cups almost wore off.
In all Not a very good pair with this gaming headsets .
As per my current possession I only have my EarPods and speakers and need some immediate recommendation .
Definitely a (headphone+mic) recommendation , and I am willing to pay anywhere around 220 bucks.
For headphones don't know much ( only heard about beyerdynamic , audio technica ) and for microphone some zalman clip on mic and boom pro .
Sorry for being so long but I really wanted to express my horrible experience with the headsets.
Any other suggestion and combination for headphones , mic would be highly appreciated
TIA
Discussion Starter #2
Bump
You can probably get a HyperX Cloud and call it a day.
Also, I think V-MODA Crossfade M-100 are up your alley as well if you can spend that much. You can swap out the cable, earpads and the cup covers to your liking.
Discussion Starter #4
TY for the reply .
I love the extreme customisation of the crossfade and I will definitely consider them . How about audio technica m50x and beyerdynamics ad500x .
Also , any microphone suggestion's?
Discussion Starter #5
Here's some pics of the damaged headset -
Not so bad. A little sodering would fix it. You can always sell them out, some people would not mind fixing it themselves, and give it a facelift, then sell it back and make some profit. I know I did. There were times where I changed just the insides.
They definitely are banged up. You can fix then it seems but you don't like them and resale is going to be a pain I think.
I should have mentioned the V-MODA Crossfade as well. It's a step down from the M-100. They are both compatible with the V-MODA BoomPro attachment which has a mic attached to it. You can always get an external mic like a desk stand, clip on or the ModMic. Personally the BoomPro takes the cake as it's all in one granted you have a set with a replaceable cord.
The ad500x is an open back and the m50x is closed back. Sound is subjective but either will perform well.
Discussion Starter #8
I will definitely gather more info and will get through the reviews on v moda cross fade .
I was just wondering how which one would be better m50x or ad500x . I know you told that m50 is a closed back and later being open one . But personally I don't know whether if it would apply to me as which one is open or closed as I am not an audiophile anyways .
I will basically use it for gaming with no one around me (at least for the most of the time).
PS - what do you think of combining a boom pro with ad500x and m50x . Will this be any good combo?
TIA
Discussion Starter #9
After a lot of reasearch I found these headphones intersting -
AUdio technica m40x ( not m50x because all the reviews stated its the same as m40x with very minimal variations which I thought wouldn't bother to me )
Audio technica pro500 mk2
Akg k240 mk2
Sennheiser momentum
Any ideas on how any these will perform with a boom pro ?
Any one using any of these headphones with boom pro ?
Thanks
Discussion Starter #10
Bump
1 - 10 of 10 Posts
