Doesnt sound like the monitors at fault, maybe re-installing drivers?
Latest versionOriginally Posted by lollingtonbear;14256806
8x, the Vsync solves the BFBC2 problem. Nw I need to check TF2. What does vsync do anyways?Originally Posted by De-Zant;14256820
Turn AA to at least 4xAA, and put vsync on. See if that fixes it.
Vsync and 8x, its not as bad as before. But I feel like it could be better yet.Originally Posted by De-Zant;14256883
Vsync syncs the GPU with the monitor so that you don't have two halves of frames displaying the same time on the monitor, resulting in the line you saw.
Hmm. You sure AA is on in TF2?
I've tryed taking screen shots but the problem is when I'm moving, it doesnt capture it. It captures the frame right in the middle.... yes max resolutionOriginally Posted by De-Zant;14256939
Hmm. Are you running max resolution?
Bleh. Just post a picture. That way it's easier.
What would that be under? 1680x1050 full screen 16:10.Originally Posted by De-Zant;14256978
Hmm. Check your CCC. Are you sure your resolution is 1080p and NOT 1080i? This is, if you are running HDMI of course
Okay so is it my card then or monitor?Originally Posted by De-Zant;14257126
Oh. Your screen is that.
Disregard.
I have no further ideas. Just wait a while for other people to reply.
