After days of searching and researching, I finally came across this excellent tutorial that makes sense, is super easy to follow and works!
I also wanted to add to this video tutorial the fact that SLI fan control does in fact work with this video tutorial method.
***SLI TIP: Set your hardware range event monitor to whichever primary or secondary VGA heats up 1st between the two and the other VGA fan will follow those set parameters.
