1 - 7 of 7 Posts
Newegg has a fairly reasonable Open Box return policy. If you quickly install and stress test the motherboard upon receipt then you can determine if the board is good or not. In the past, I've had good luck ordering Newegg Open Box CPUs, DVD Drives, and HDDs. Just remember, if it's bad, Newegg must possess it within 30 days of the invoice.
How many volts!?
I've had good luck with OB items from Newegg. Never had a dud, always been complete, just never came with the original packaging. 2 motherboards, and a few GPU's. Awesome price, for missing the original box.
How many volts!?
Originally Posted by Zebz View Post
But if it does come with a UPC it would be available for a ASRock warranty..?
I believe they go off serial numbers for warranties. I would call ASRock or even check their website to be 100% sure before purchasing so that way if it does indeed crap out after 30 days you're covered.
1 - 7 of 7 Posts
