Rma?
281 Views 9 Replies 5 Participants Last post by  NickOulton
ok so i ordered a power supply a while ago and just recently got it. when i opened it i notice one of the pins from the 24pin atx connector was missing. not only was the pin missing, the whole wire was not to be found. should i RMA it?
1 - 10 of 10 Posts
Uh, definitely yes.
It is probably the -5v line. That's normal since it was removed for the ATX specs many years ago.
Which wire is it? http://pinouts.ru/Power/atx_v2_pinout.shtml
Originally Posted by Admiral Mudkipz View Post
Uh, definitely yes.
Your current PSU is missing this wire as well.
Originally Posted by DuckieHo View Post
It is probably the +5v line. That's normal since it was removed for the ATX specs many years ago.
Yup!
Even though I'm new to OCN, I second this.
Originally Posted by microman View Post
Yup!
Sorry..... -5v
thanks i just reaserched it and found out its normal and shouldnt worry unless i have an old school mobo... which i dont.
ps. im sure its the -5volt line not the +5 (EDIT nvm... you beat me to it)
Look above.
the 20th one... which is the -5v lol thanks for the help
Look above.
lol fixed it
1 - 10 of 10 Posts
