Roccat Hiro 3D Supremacy Surface Gaming Mousepad (ROC-13-410)
Description:
If you're looking for a battle base offering supreme acceleration- and accuracy-enhancing properties - combined with some of the most advanced build construction ever found in a gaming pad - look no further than the ROCCAT Hiro - 3D Supremacy Surface Gaming Mousepad.
Thanks to its exclusive 3D vulcanized silicone surface, mouse gliding on the Hiro is simply amazing: smooth and effortless, yet offering incredible precision. The Hiro easily boosts the speed and control of any mouse to phenomenal levels, providing demanding skirmishers the sure upper hand.
And with its additional range of exclusive build innovations - including smooth, rounded edges that won't fray - the Hiro is an ideal tool for any gamer looking to reign supreme.
VULCANIZED SILICONE SURFACE
with complex 3D structure for total speed & control domination
POWER-BONDED CONSTRUCTION
for smooth, rounded edges that won't fray
COVERT-TECH SURFACE TREATMENT
for ultra-quiet gliding
NON-SLIP, SHOCK-ABSORBING RUBBER BASE
for the steadiest command platform & longest battle comfort
FORCE FIELD PROTECTIVE COATING
water resistant & easy to clean
PREMIUM MATERIALS CONSTRUCTION
for max battle durability, mission after mission
OPTIMAL GAMING SIZE
of 350 x 250 x 2.5mm - for ideal ergonomics and performanc
Description:
OPTIMAL GAMING SIZE
