Is it more than the 3500/3600 dpi??
Well I think I'm going to buy it, I hope that it will not be so bad :/
You mean clicks latency?
I already have the Roccat kone pure military, which I like the shape, it's just perfect for me, but the dpi bug annoyes me a lot, so wanted to know more about the kone pure optical.Originally Posted by uaokkkkkkkk
My take on it is that if you are going to buy it, buy it if you like the shape.
If you don't like the shape, there are many alternatives on the market you can try.
Hell, supposedly there's a firmware for the Kone Pure that adds button delay when the mouse is lifted off the pad.
However, the person that discovered the feature never specified what fw version was tested, or if it was a feature exclusive to that specific firmware release.
I know that's the reason why i want to change to the kone pure optical, cause it doesnt have the dpi bug, unlike the kpm, where you need to enable dcu to fix it but then you will get a good amount of smoothness.
Well the smoothing in the 3310 sensors is known, but it seems like the rival is the one with biggest amount smoothing from all the 3310 mice.Originally Posted by trism
I don't know how good the A3090 implementation is in the KPO but I don't think it's such a huge issue. Heck, r0ach himself () uses/used the Kana v2 which has the A3090 with the 4000 CPI SROM.![]()
PMW3310 has sensor level smoothing so KPM has smoothing even with DCU set to off.
Wonder why scream is using it then XD.
He was using the 2013 DeathAdder when it came out until the RGB version was released. Then he went to the Final Mouse. He's used to it by now.
