1 - 6 of 6 Posts
Well help me decide which one it's better
thanks guys
the reason it's a tough decision, is that I'm a claw grip/palm grip guy, i use my arm and wrist and i think i like small mouses, i think i got a small/medium hand. If you need any more information let me know
ROCCAT Kone XTD Max Customization
http://www.roccat.org/Products/Gaming-Mice/ROCCAT-Kone-XTD/
ROCCAT Kone Pure Core Performance
http://www.roccat.org/Products/Gaming-Mice/ROCCAT-Kone-Pure/
RAZER Imperator 4G
http://www.razerzone.com/gaming-mice/razer-imperator
RAZER Deathadder
http://www.razerzone.com/gaming-mice/razer-deathadder
I'm really a noob when comes to gaming mouses
Let's see.
Kone XTD - laser mouse. trash.
Kone Pure - laser mouse. trash.
Imperator 4G - PTE mouse with CPI scaling. trash.
DeathAdder - definitely the best of the ones you listed. the 2013 isn't bad, but there are better.
Like the guy above said, check out the Avior 7000. If you're a claw/palm it should fit you will. I also have a review thread you should be able to find pretty easily.
Originally Posted by Beluga View Post
thanks man
No problem, I have experience with every major type of gaming mouse sensor available today, namely:
VSCEL (referred to as "laser" even though this is an optical sensor illuminated by a laser instead of an LED): aka ADNS-9500/9800 and their derivatives
LED or IR optical (commonly known as just "optical"): 3090, 3310
PTE (Philips Twin Eye, aka twin laser, it is a doppler effect sensor): PLN2031
Some opticals are flawed, all PTE and laser mice are flawed, especially for FPS players. I'm saving peoples' butts on here, one at a time in not being burned by OMG THIS HAS 8200 CPI IT MUST BE EPIC marketing bull****. Just no.
1 - 6 of 6 Posts
