Rocketdock pros, help?
1326 Views 2 Replies 3 Participants Last post by  Volcom13
Just discovered RD
Couple of questions:
How do I add the W7 explorer feature(libraries)?
I want to totally be free of the W7 taskbar and sidebar, how can I achieve this?
I want a clock, calender, basically everything you can put in the sidebar.
Thanks
Attachment 130793
See how tacky the sidebar looks.
1 - 3 of 3 Posts
Well, they're called Docklets (the apps on your Dock). I use Stardock Objectdock and have a weather and calendar docklet.
http://rocketdock.com/addons/docklets
Rainmeter will be a good improvement from using the Windows Sidebar.
http://rainmeter.net/RainCMS/
You can get skins here:
http://customize.org/rainmeter/skins
1 - 3 of 3 Posts
