Rocketfish Owners Is PC-343B Fan Module The Correct Item?
830 Views 4 Replies 3 Participants Last post by  lsdmeasap
Just wondered if my fellow RocketFish owners could tell me if this is the correct item to fit in the RocketFish bays
Lian Li PC-343B
http://www.performance-pcs.com/catal...ducts_id=21092
Just wanted to be sure, as I see several "Fan Modules" now at when there used to be only two I thought.
See this one as well so not sure
http://www.performance-pcs.com/catal...ducts_id=26271
And this one, I believe the same in Silver
http://www.performance-pcs.com/catal...ducts_id=21871
I want to know if I can use the first black one I linked
1 - 5 of 5 Posts
Will a mod please move this to the case section, I think the case mod section was the wrong place to post this.
Thanks
Just a note, I had on in my rocketfish and it worked just great.
Thanks guys, I will go ahead and order one from PPC's then.
Just wanted to be sure as someone told me either of the three might work but I just didn't like the "might" answer.
1 - 5 of 5 Posts
