Are you only basing that on those timings and everything on Auto or are you actually using the Ryzen DRAM calculator to input the other timings?
14-13-13-28 is pretty aggressive. I can't boot at all with those timings on any BIOS version. Either you have a good kit or input a lot of other timings not mentioned.
To fully test this you NEED to input other timings. Simply selecting the preset ones or inputting those few timings and leaving everything else on Auto is not sufficient. The auto settings could have changed and now are not compatible with your RAM if this is the case.
Also voltages aren't listed. SOC, DDR, DDR Boot, etc etc. If you're going to provide feedback, please provide everything/upload your saved BIOS settings.
I spent all day working on it.
The timings I am using that work are The Stilt's Fast 3200 B-die preset. Works like a charm - 12~14 hours of stress testing the memory without an issue.
The settings I used with this memory before (all custom using the DRAM Calculator) no longer work to make 3600 stable. The 3600 preset in the BIOS also doesn't work, though it used to be fine with 3466. I pushed DRAM boot to 1.46V and DRAM to 1.45V, played with the SoC voltage (in both directions), and even underclocked the cores for good measure. Everything above 3200 would fail with this BIOS despite 6101 being able to run these same (or similar) settings.
It never became truly unstable except at 3733 where the system froze under stress testing, but AIDA64 was able to detect a failure within minutes of starting the memory-only stress test.
I played with gear down, power down, bank group swap, command rate, termination resistances, and all of the subtimings. There's no way to summarize, but I can share what is currently stable.
