Mode0 was somehow Linux related, but I have no additional info on that.
SoC Overclock VID allows you to override the default (static) VID the SoC domain requests from the VRM controller.
OC VID in HEX = ((1.55 - "the desired voltage") * 160).
Dear Stilt, what do you think is the problem with my case.
C7H with 0509 UEFI, ubuntu 18.04-> run ryzen kill script (it's cpu at 100% load but with temps about 50C so it's not real 100% load) for ~44h
C7H with 0509 UEFI, win10 1803 build(new one) -> random shutdown while stress test, cpu temps are fine, So it shutdown, can't turn on pc need to turn off/turn on PSU and then I can turn on PC. I can't stress test more than 5h, it worked like even 8h after 2nd shutdown, but after than I run occt small and it did it again after 15 mins. so it's random maybe even related to some of stress test software which i don't think is the case.
So is it windows problem or bios or motherboard?
UPDATE: I reinstalled windows10 and there is an asus automatic updater that pops up and i don't want to install it. It's like red box. Anyone got this too?
