12361 - 12380 of 12851 Posts
Updated the Prime Pro with 1.1.8.0 too, works fine with a 2700X
For my 3700X the new bios 4001 does not work.It will boot ,but under load it will not boost , i have only 550 mhz.
Did you turn on Fmax in the PBO menu? And did you enable Core Performance Boost?
Yes ,Core performence boost was allways on . The Fmax i tried it ,in on and off mode,same with PBO. Serveral cmos-resets and loded optimal setting in Bios were done . Flashed it in normal and second time via flashback mode.Same wired behavior. Back to 3103 and all is normal.
Well you're not missing out on anything. I'm seeing the same performance with no notable changes. I haven't gone back to a previous BIOS simply because I haven't had any problems. I'm hoping the Curve Optimizer eventually gets ported for Ryzen 3000 use.
Computer Enthusiast
At last something to play with!
What are the settings you need to use with FMax?
I just turn it on and pair it with the PPT and TDC settings I had when using the EDC bug. Which were 147 and 120 respectively. Then I set LLC to 1 and add a positive CPU offest of .01250V.
Nick name, what are your ram timings and Vs? Im going to try 3800 again
DRAM 1.52V (droops to 1.504V)
SOC 1.1V
VDDG 1.05V
VDDP 1.0V
I installed 32GB and didn't feel like chasing max performance and then testing so I set 16-16-16-16. It will do 14-15-14-14 with a lower tRFC, but I didn't feel like testing for stability.
Edit:
I forgot to check, but I now see the tRDWR tWRRD Auto bug is still there. I'm gonna go back and set those to 8 and 2.
2466593
Reactions: Dude970
Thank you, will give a try soon
With this BIOS it sets tRDRDSD and tRDRDDD to different values when left on Auto. The same for tWRWRSD and tWRWRDD.
u guys are not seeing Fmax pushing it ? i just activated and it started acting a bit like an xt model.. 540 cpu-z single, never seen it that high before
2466642
what bios is that? the 4001 on asus website or the 0019 test bios shamino posted in this thread earlier?
i think im getting the best performance ever from this bios without a fixed OC, just with Fmax activated, PBO enabled and all votages on stock, it seems to be running consistenly at 4.5GHz SC and its pushing for 4.35ish MC.
Only negative is that latency might have increased a little.
also i found out the hard way after a few dozen crashes LLC is not compatible with Fmax
2466726
Thanks for the head up on LLC, yes Fmax runs pretty well. Not as high performance as my Per CCX OC, but definetely a lot better than Auto. CB R23 now runs at 4250-4300MHz all cores vs 4050MHz on Auto. Not much benefit on single core scores though, Per CCX is a lot better. Maybe because Windows scheduler is crap. Best CCD now regularly boosts to 4600MHz even occasional 4625MHz. On Auto 4525MHz was the highest, so a 100MHz win.
3900x Fmax on, PBO auto, Voltage Auto
ram at 3600 cl16
that was while playing forza 7 for 20 min
2466763
