13021 - 13025 of 13025 Posts
How is the latest bios releases working out for 5000 series owners here? I've just got a 5900x and a new gskill trident z neo ram kit 3600 14-15-15-35 on its way and not sure which bios i should start with? I'm currently on bios 2801 with my 3800x running at 4.5ghz with a 3800cl14 oc on a trident z royal 2x8 gb kit
Use the latest 4301 bios, earlier bioses had two problems a. idle reboot and b. USB issues(with 5-series, not 3-series), sheer performance is less important than booth of those
Always use Bios Flashback when flashing a new bios
Well 4301 is based on agesa 1.2.0.1 which does have some usb fixes ,Hopefully the next release will be based on 1.2.0.2 so should fix all usb issues with ryzen 5000 series....
well my 5900x and new ram arrived, installed them and flashed to bios 4301 using flashback no issues so far
2488688
2488689
2488690
2488710
2488711
Started to tweak my ram I'm only at 3600 for now haven't tried to see how far I can push my fclk yet
2488995
2488996
I managed to get 3733cl14 and 3800cl16 ram working as well but the same old issue of fclk dropping out of sync after waking from sleep if running higher than 1800fclk is still present so I'm just gonna keep my ram at 3600cl14 for now, the last bios that didn't have the fclk dropping out of sync after waking from sleep was bios 2801
2489260
2489261
