13061 - 13080 of 13169 Posts
Are you using the same EDC settings?
Normally I leave PBO menu to auto, only touch Performance Enhancer LV1
other CPU related are :: CPU LLC3, CPU Current Cap 130%, CPU Thermal Control 120 (all the same as bios v2103)
the weird is Performance Enhancer LV1 gave EDC 140A while Performance Enhancer default gave 150A
Went back to 4301 a month back, no longer having issues with my Xonar, but shrug - no f clue why it suddenly works other then the far off possibility it was a windows issue.
I need your support, please check the screenshots. Is something wrong? (I remember a latency of 67ns with 2700X PE lvl 2 GDM ON and CR1)
CPU 3800X
F4-3200C14D-16GTZRX
Trident Z RGB (For AMD)
DDR4-3200MHz CL14-14-14-34 1.35V
16GB (2x8GB)
Reactions: kratosatlante
CPU 3800X
F4-3200C14D-16GTZRX
16GB (2x8GB)
got to cl12 easy for your kit, gain fps in games
Enthusiast
CPU 3800X
F4-3200C14D-16GTZRX
16GB (2x8GB)
It is 3200mhz. what do you expect? you should oc to 3600 if you want more. Also, your cpu is 3800xt, not x.
Yep, it's 3800XT. Just checking that the memory is not underperforming. I've not tried 3600 C16, I'll give a try, but after a BIOS update I've some trouble inserting the values on fields, i.e. sometimes 316 become 3166666666.
Finally have a 5950x on the way from B&H to go in the C7. Super excited, been waiting ages to snag one at MSRP.
Been a long time since I've looked through here, is there an ideal bios to use other than what's posted on the Asus site?
BOINC Cruncher
Serenity Numbskull
Congratz. I too had been waiting ages to snag a 5950X at MSRP. Finally did last week at Amazon. Replaced my 3950X on Monday and have it up and running now in the daily driver. Moved the old 3950X into the 3900X host yesterday. Now still waiting for my preorders for my Epyc 7443P cpu to come in. Those are still unobtainium. I will then move my Epyc 7402P into the TR 2920X host.
BOINC Cruncher
Serenity Numbskull
Congrats yourself :p Any issues with the update to the 5 series compatible bios on the C7H? Which version did you update to?
I was on 4204 but upgraded to 4301 BIOS. But I had all kinds of flaky things going on that caused me to swap gpus and revert back to 4204. Probably nothing to do with the BIOS. I thought that basically just dropping the 5950X into the existing 3950X host would be pretty painless. But that is not the case. Whole different beasts in my opinion. These Zen 3 cpus run HOT! Had to make some accommodations and adjustments. Still tuning actually. I am stable now but will attempt to get a little more out of it now that I understand it a bit better. Still have to swap the gpu back in to see if it was the real cause of the instability. That is the project for tomorrow.
Black Sun Empire
Hi all,
anyone here knows if this board has a built in tpm module(for the coming windows 11...its a requirement) or do i have to buy one extra? which one would you guys order
Gesendet von meinem SM-G950F mit Tapatalk
BOINC Cruncher
Serenity Numbskull
Hi all,
Yes it does. See the manual for the fTPM configuration to Enable it.
Reactions: Wuest3nFuchs
Overclocker
My CPU degraded... :(
First it wouldn't run at 3800 MHz RAM anymore and now it won't let me run 4.4 GHz anymore..
It doesn't crash or anything but i get mouse issues and WHEA errors en in OCCT it failed under PSU test. That test makes the CPU hot AF man! It made it run at 80c +! Never seen this temp before and within 20 min it failed :(.
I am still thinking of what a better buy would be, new Asus rog x570 dark hero or 5000 CPU:unsure:
Hi all,
i believe all ryzen 2000(zen+) and up have tpm2.0 built into the cpu. They called it ftpm
you do not need extra module or hardware on the motherboard.
Black Sun Empire
thank you guys !
Windows 11 update confirmed working on all my AM4 boards, CH8 and Prime Pro has headers and needs switching to "firmware" under TPM in bios. B550-F and CH7 doesn't have a header and just needs "enable" in bios.
Ok so 5950x went in today without any drama after 4301 update.
Full auto except ram timings and dram voltage goes to 5040 single core.
682 cpuz bench single
12693 all core.
If I understand right, haven't been paying attention to 5000, but best boost results will come from doing the per core undervolt right?
Is that in the AMD section? Didn't see it in extreme tweaker.
Sadly, fclk stability was better on 3900x, 1903 vs 1867 max.
