13521 - 13533 of 13533 Posts
What are your temps? If I hit mine with Prime95 I get crazy numbers, and that's with 420 Liquid Freezer II
Also I'm not sure which of those are real temps anymore...
I haven't bothered to run any cpu heavy stress tests as you can't overclock the 5800x3d anyway I've only tuned my ram and used Tm5 anta777 extreme + karhu ramtest to test for stability
gaming my temps are fine sub 70c with an ek 360 aio with 6x120mm fans push/pull at low rpm
WOOOO this is nice!!
5800x3d 32gb 4x 8gb 3200mhz cl14 and XTXH 6900Xt
System is running smoothly so far with negative voltage offset plus level 1 LLC to introduce vDroop
Reactions: Wuest3nFuchs
Any clock stretching?
Maybe someone can help me explain why my bios has a big black bar on top of the screen? Worked perfectly fine when i had my 5700XT GPU, upgraded to a 6700XT in May, and its been like this ever since. Tried different bioses, same issue. The buttons can still be used, I just can't see them. Anyone else have this issue? No issues once I get into Windows, everything works perfectly.
have you tried connecting your display to a different port on your gpu or try different display cables?
At -0.1000mv no noticeable clock stretching(results for Firestrike and Timespy are within margin of error), but going to -0.18750mv there is some heavy clock stretching, 15% from CPU score on firestrike and 8.7% on Time Spy CPU Score
Could you share your voltage offset value? Im upgrading to 5800x3d soon, maybe 5800x not positive yet.
I found my perfect balance is at -0.1000mv + LLC at level 1 on this board. This introduces heavy vDroop without dipping into the clock stretching that Ryzen has.
If you're gaming at 1440p/4k -0.18750mv is perfect with LLC at level 1.
Keep in mind, this is not touching PBO at all, purely stock 5800x3D.
This new Bios version (4901) breaks Asus AI Suite 3. I had to downgrade bios to get AI Suite to work again.
My Rig is :
ROG CROSSHAIR VII HERO (WI-FI)
AMD X470 chipset
CPU Ryzen 7 2700X
Windows 10 x64
Is AI suite useful ? I though it was just Asus junkware
On my 5800X I cannot seem to reach the same boost clocks I did with the previous BIOS 4703. The other weird bit is that far greater negative offsets don't result in clock-stretching. It's odd.
Edit:
NVM. I am an idiot and completely forgot about Curve Optimizer. I also forgot what my stable settings were though this BIOS does seem to suffer less from clock stretching.
Did I do something to cause it or does this BIOS cap max voltage at 1.4V?
Edit:
It appears that when you manually set EDC it caps the voltage. So I was using an EDC of 142 and couple with a negative offset of .025 I was capped at 1.4V. When I changed EDC to Auto voltage went back to the normal max of 1.5V
