Had two C6H boards at launch; neither one made any noise at all. Wouldn't expect C7H to either.Did anyone check if the C7H's VRM section emits less audible noise than the one on the C6H?
If you are able to manually overclock and get the cpu to downvolt pls inform me on how you did so. also you have the 1700x so i'm not sure it still applies but what are your temps spiking at if you were to use XFR. i attached a file of whats happening to my Vcore while its manually overclocked it won't downvolt.Right, I'm up and running on my C7H - lots to learn! Running nice and smooth at stock...... Love all the new bios options!
I'm I right that SenseMi/Skew needs disabling? Is there anything else I need to know or do (other than update bios) before I go OCing my new board?
I did have a quick go at getting my 1700x to run at 4.2 GHz like it did on Prime x370 Pro, but seems to be a no-go....using the same settings anyway.
Too tired right now so going to do my OC from beginning tomorrow.... there's bound to be differences I need to take into account....
Looks like your CPU is downvolting. See CPU Core VID, this should show if the CPU is downvolting or not. You should not expect correct reading of all sensor's data on earlier versions of motherboards and CPU, maybe on later and more refined BIOS versions.If you are able to manually overclock and get the cpu to downvolt pls inform me on how you did so. also you have the 1700x so i'm not sure it still applies but what are your temps spiking at if you were to use XFR. i attached a file of whats happening to my Vcore while its manually overclocked it won't downvolt.
Thanks for this reassurance thing is only the VID of those 2 cores drop all others stay the same guess i have to wait for further bios versions.Looks like your CPU is downvolting. See CPU Core VID, this should show if the CPU is downvolting or not. You should not expect correct reading of all sensor's data on earlier versions of motherboards and CPU, maybe on later and more refined BIOS versions.
Did you have to remove the power plug for the power button to work? That was what my issue was. Which MOBO do you have?Just had this super weird issue where my pc just shut off completely. No warning or anything just shut down. So its happening whenever i don't run default settings in bios. even running Performance Enhancer 1 caused it to shut off without warning just shuts off like if it were unplugged Mobo lights stay on. not sure what can be the cause.
Sent from my iPhone using Tapatalk Pro
i had to turn off the PSU for it to work not remove it. CH7 MOBO how did you fix it?Did you have to remove the power plug for the power button to work? That was what my issue was. Which MOBO do you have?
Turning off the PSU for some time worked as well(Had to wait about 10s for power to drain etc). I bought a new PSU, and i've been stable for 14 hours, but my issue was so sporadic i'm not sure that its fixed yet. Somtimes it would take 1 hour to pop up sometimes it took 17 hours. Happened stock, and OC'd. You were OCing right? What settings were you using?i had to turn off the PSU for it to work not remove it. CH7 MOBO how did you fix it?
Yeah, if my new PSU doesn't resolve this its RMA time.I was over locking when it happens it’s also sporadic I have an evga 850 fully modular but it’s not even a year old. It happens with a manual overclock to 4.12 and Under performance enhancer 1 which I don’t think should have caused it not quite sure what’s happened hopefully it’s not the psu if it happens again I’ll try to reseat cables if not rma time
Thanks - I'm thinking of getting one of these as my Prime Pro really isn't great, never really been happy with it - others with my ram get much better OCing than me and the sound died on it about a month after I got it
Are you able to adjust the boost/XFR settings in bios?
@elmor are the different memory implementations between P x370 Pro and CH7 significant?
Seems only the WiFi model is available here at the moment, is BIOS development going to be the same with X470 as it was previously where the C6H was the main development board while the C6H WiFi and C6E got BIOS updates much less frequently?
Not sure if anyone can help me out but I can’t seem to downvolt my cpu if I manually overclock it. I’ve tried just changing Pstate with auto voltage still doesn’t downvolt same story with offset voltage. And I’ve also tried 42 core ratio with offset no downvolting according to svi2
Does anyone know if the PE level 3 is safe at those voltages? Getting 1.5+ spikes the temps are completely fine Tdie won’t go past 55C while gaming and stress test are around 70C but those spikes honestly trip me out on single cores it’s hovering at 1.45-1.55 @elmor insight would be great here
That's disappointing if so, I'm pretty sure voltages get reported wrongly on the C6H and I'd hoped they would have fixed that on the C7H.
Is anyone aware of the CH VII shutting down, and the power button won't turn it back on, you have to remove the power plug for a few seconds to allow it to turn back on. Wonder what could be causing that. Happened both with my 1700, and 2700X on different BIOS's
I added the latest BIOS 0601 for C7H/WIFI to the OP.
I'm not working with the Prime so wouldn't know. I believe it would be a similar change as from C6H, better optimized for using 2 DIMMs but worse for 4 DIMMs.
Our primary development board is the C7H WIFI.
Make sure Advanced\AMD CBS\Zen Common Options\Global C-States Control is Enabled and that your OS power profile has a low enough value set for the minimum processor state.
Check the SVI2 TFN Core Voltage reading in HWInfo. Up to at least 1.5V in low load scenarios (few threads used) should be ok.
We've implemented several things to fix this. BIOS and AiSuite is already very accurate if you're on BIOS 0505 or later. Third party software does not have all the fixes yet.
Any red LEDs lighting up on the board? Can you test it on BIOS 0601 I just uploaded?
Wow, the next one with this weird "sudden shutdown" issue.Just had this super weird issue where my pc just shut off completely. No warning or anything just shut down. So its happening whenever i don't run default settings in bios. even running Performance Enhancer 1 caused it to shut off without warning just shuts off like if it were unplugged Mobo lights stay on. not sure what can be the cause.
If you read my post above i think my issue was related to my Case/PSU. I was having all sorts of issues. I think my mobo was grounded in my case. Maybe not, but i'm testing now. I can update you tomorrow if you remind me.Wow, the next one with this weird "sudden shutdown" issue.
I really hope ASUS will investigate.
