1 - 4 of 4 Posts
I'm planning on building 3 HTPC in a small mini-ITX case. I'm looking at a Rosewill RS-MI-01 BK - Mini ITX Tower and it comes with a AL8250SFX PSU. I'm wondering if it can handle these rigs?
2 rigs will be this
CPU : AMD Athlon 5350 Kabini Quad-Core 2.05 GHz Socket AM1 25W \
Mobo : ECS KAM1-I (V1.0) AM1
Memory : 1 8gb 1600 1.5v
HDD: 120gb SSD
ROM : DVD burner
The 3rd is this
Memory : 1 8gb 1866 1.65v
HDD: 1TB WD blue
ROM : Blu-ray player
All 3 will be using the on-chip video.
Here is a pic on the spec on the PSU.
Senior OCN Member
It can do a total of 236 watts 192 of which is on the 12v rail.
No idea how much those systems draw.
RIP OCN 2018
With ease. Heck, I'd dare to run it on a decent 80W or 100W PSU.
Your hardware has very low power requirements.
I have an intel dual core celeron (sandy bridge) system with 1 stick RAM and 1 SSD. Draws about 20 watts at the wall, 30 under prime load at the wall. Your system is an even smaller power envelope. You could easily run 4 of thsoe systems on the same tiny power supply. You are fine.
1 - 4 of 4 Posts
