Rosewill "Stallion" Series, Any good?
3740 Views 14 Replies 7 Participants Last post by  Opeth07
So there's a deal on the egg right now.. this PSU is going for $50 bucks right now after promo code.. Is it worth it?
Will this psu be "quality"?
I'm on a tight budget, corsairs look nice and all.. but they're on the very high side of my budget.
What makes PSU's like corsair's "quality" and "unable" to like,fry?, your pc, ect?
1 - 15 of 15 Posts
I had one rosewill psu and it worked just fine,I had no problems with it.But you might wanna go with a better brand.maybe something like this
http://www.newegg.com/Product/Produc...82E16817341010
i have a nice rosewill 550w that has been rockin the **** for like 2 years of heavy abuse so i would say buy that ish up
Corsair 400w $39.99 ---
or
Roswill 600w $50 ---
edit: I gave both of you rep for some reassurance, I'm leaning towards the rosewill <_<
It's an ATNG built unit. I wouldn't call it bad, but it built cheaply with a single layer PCB and less than stellar caps. That Corsair is a much better unit, but at 400W it is fairly limited to what it can run. The Rosewill comes in at $56 shipped after the promo code. If you didn't mind rebates this is what I would go for: http://www.newegg.com/Product/Produc...82E16817341010. It is still isn't as the Corsair in build quality, but it is better than the Rosewill.
Thank you, I'm going to go with OCZ. +rep
I've been using my Rosewill Stallion 750W since Oct. 2007 amd its still going strong....if thats any indication of the quality
Originally Posted by mothow View Post
how about this
http://www.newegg.com/Product/Produc...H4A-_-17341022
I just saw this deal too in the newsletter.. an additional $10 promo code brings it to $59.99 .... Seems good to me.. any expert opinions?
Well 13 reviewers gave it 5 stars .It cant be to bad.But then alot of newegg reviews are by morons
We don't know for sure about the 400 and 550W Fatal1ty but from the pics on newegg I'm pretty sure it is the same build as the ModX Pro from Sirtec/Sirfa. Nothing amazing but not bad either. With the promo code and rebate it's a pretty good deal for a somewhat decent modular 550W unit.
Hmm.. I thought I was sold on the 600w stealthxstream but this one is 10 dollars (and 50w) less --but im sure more than enough to power a mediocre gaming machine (xfire 4830's-- big wow)
thanks shinji2k --you're really reassuring
+rep
Probably going to check out the "Modx" non-fatality versions first then, to see if they're any cheaper
I'm probably making a PSU buy harder than it has to be. I can't decide!!
I've had my rosewill for over a year now and its been going strong.
1 - 15 of 15 Posts
