RRR RRR RRR what is this?
804 Views 20 Replies 5 Participants Last post by  lsvtec
After installing new cpu onto motherboard this is what happens when booted. i can go into bios fine. but after that first screen the RRRRRRR appears..
im running p5n e sli with e7400
1 - 20 of 21 Posts
the "RRRRRRRR" ?
yes a whole line up top screen RRRRRRRRRRRRRRRRR
Are you using the latest bios? 1301 I think the last one was.
it worked fine before with the q6600..
The p5n e sli didn't support 45nm chips until the later bios
q6600 is a 65nm
so do i have to update the biios for it to work
maybe your "r" key is stuck down?
it sounds to me.that your mobo does not support that e7400
I dont know. What bios do you have now ?
If it is one of the older bios then I would suggest updating to the latest bios first and see how it goes from there.
If it is one of the older ones then I would suggest updating to the latest bios first and see how it goes from there.
Here just found this, it says you need 1301 bios
http://support.asus.com/cpusupport/c...el=P5N-E%20SLI
sounds good ill let you know tomorrow, if it works with the new bios.. i'm still runngin on the stock bios..
oh do you know where i can get an update on this.. tried updating it on the site, but not seemin to work. thanks
i guess it does support it,was trying to get to that page earilier,it just loads so slow
http://support.asus.com/download/dow...0SLI&product=1
This worked for me, unpack and put the files on a usb flash drive, enter bios on boot and goto ez bios flash(i think,not at home on my own computer) and flash from the there
Yeah its EZ-flash.
Its in the tools tab.
which one do i downlaod
1301k i see it ... tanks ill try tthis tomorrow morning gotta catch my zzz.. appreaciate the he;p
Nighty night... don't catch any RRRR's
Remember to let us know how it worked out for you ?
But it looks like you need the 1301 bios for the E7400
Thanks +1 For you guys, I got it working. Not as fast as the quad core, but its running perfect for my daughter, I have to RMA my evga board now.. moving things around sure f#$% my board up.
thanks
1 - 20 of 21 Posts
